Are internal wallpapers available?
Are there any wallpapers showing the internals of the OnePlus 5T available to download?
Hi @c4artz ,
I can't find any online but as a workaround you may wish to try the following.
Here is a link to the ifixit OnePlus 5T repair guides.
If you select a guide, you can watch the video and then stop it at a suitable point for the picture that you want to have as a wallpaper and then take a screenshot.
Use a picture editing program to edit the picture to suit and then use this app to convert it to a wallpaper for your phone.
Here is an image that I've taken from the OnePlus 5T Battery Replacement guide as an example of what you might be able to use.
(click on image to enlarge for better viewing)
I do not know the ethics of doing this, but perhaps if you contact the author of the videos (@witrigs ) and ask for permission, he may oblige as presumably it will be for your personal use only.
このアンサーは役に立ちましたか?
I tried this solution. Problem is that the phone gets opened up from the back unlike the iPhone. So you're seeing the backside internals. But thank you for your tipp
Good answer . Never thought of doing that , neat idea
過去 24時間: 1
過去 7 日: 7
過去 30 日: 9
今までの合計 3,004
