Radio buttons on steering wheel not working
Radio buttons on steering wheel that allow you to change from one station to another work when car is simply turned on (engine not running), but don't work when engine is turned on. (Can't change from one preset station to another). Volume control works both ways and all other functions work just fine (touch screen, control knobs) in both situations. 2016 Nissan Rogue
この質問は役に立ちましたか?
7 件のコメント
Have you ever been able to change the station presets while engine is on? If not, then this is likely a factory option. If so, then it is possible that your steering switch is broken. You could try scanning for codes, just incase.
sm_vulkus さんによる
Yes, we could change the stations from the steering wheel. And the volume controls on the steering wheel still work. In fact only this one feature has stopped working. Called Nissan and will be taking the car in for repair. They had no other suggestions.
Thanks for your input.
Bill Luftig さんによる
Every time I turn left that shuts off my radio and my DVD what could this be
Dudden Jim さんによる
Dudden Jim - I would say this mostly likely a short in the wiring harness between your steering wheel and the head unit. I would check on crutchfield.com in the FAQ I believe they have a solution for this problem.
Luke Harwin さんによる
Dudden Jim - sounds like the clockspring behind the steering wheel could be bad. Any repair shop should be able to test and replace if necessary.
Eric Viitala さんによる
2件以上のコメントを表示
