メインコンテンツにスキップ
The Dell Inspiron 14-7437 is pre-installed with Windows 8, has 4th generation Intel Core processors and a 14-inch display.
8回答 すべてを表示
My laptop is not charging, help!
Hi,
My laptop stopped charging recently. It works when plugged in but says "1%, not charging. Power mode (plugged in)." My first response was buying a new charger but the same thing happened. So I thought it must be the power jack. I ordered one on ebay and replaced it today. But the same thing happened - 1%, not charging...help! What else could it be?
Thanks Magda
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
Hi @magbrown? had you checked about the battery?
さんによる
what are you doing while you have this issue? you doing anything resource intensive?
さんによる
No, not at all. I’m just simply using my laptop whilst pugged in. When I unplug it the laptop imediatelly turns itself off :( Thanks
さんによる
コメントを追加
1 件の回答
Try replacing the battery, and/or the pins and cables connecting the battery to the power jack and motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The laptop is only two years old. Do you think it could be the battery? Thanks :)
さんによる
コメントを追加
回答を追加する
Magdalena Browning さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 296
