メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1696回答 すべてを表示
My ps4 switches on but with no signal
My ps4 switches on completely but with no video at all. I have switched TVs, changed hdmi ports, changed hdmi cables and even a month or two ago got a completely new hdmi port on my ps4 put in and it worked fine until yesterday. Ive even tried going into safe mode but no luck. My ps4 was on and th light was blue etc. So I decided to put my headphones in and I can hear in my headset the menu and all the noises when navigating. I really need some help as soon as possible.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
if you replaced your HDMI port yourself, which got it working, then it stopped working again, it could very well be that the HDMI port either went bad, got damages, or pulled a pin off the board.
if you have good experience with soldering, Attach anotherone yourself. if you dont solder often, i suggest getting it repaired through a store.
if the HDMI port doesnt fix the issue, run through a reflow on the GPU. This may getit working.
if it continues to fail, then you are looking at a board failure. in this case, replacing the device is your best option.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
The first thing you need to do i go to best buy and buy a new ps4 hoped i helped
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
== Heading text== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text =='bold text' == == == == == ==
さんによる
コメントを追加
回答を追加する
Ihsaan Khan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 9,616
