メインコンテンツにスキップ
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16回答 すべてを表示
Will parts be same from 1998 4runner to a 2001 4runner
Would a 1998 toyota 4runner front bumper and headlight assembly and bumper fit my 2001 toyota 4runner?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
@natashadianne1 yes it should. If in doubt have either a recycler or the parts store check it in their interchange manual. My manual says that they are the same part numbers.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
96-98 are the same other than grill and minor cosmetics. 99-02 are the same other than grill and cosmetics. Headlights are interchangable, but the bumper may not be. The 99 and up have whats sometimes referred to as the "fat lip" bumper and the turn signals are removed from the bumper to below the bumper. As far as bolting and lining up, they should all work...96-02 3rd gen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Will 95 front diff fit on a 98
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes some enter brackets are different on the side of bumper behind the fenders. They are about a inch shorter than those on a 97 model. They are v shaped brackets
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Natasha D Brown さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 20
過去 30 日: 47
今までの合計 3,497
