メインコンテンツにスキップ
The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
20回答 すべてを表示
Not charging/functioning after getting base wet
Good afternoon,
Had an unfortunate run in between my iRoomba, the tile floor, and my dog who couldn't hold in her bowels. Post-event, I attempted to clean the bot manually with water and dilute cleaning solution. The unit (650) now does not seem to be able to turn on/charge. Can you please advise on how I can troubleshoot to find the problem? Thank you for your time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@brettvet hope your dog is okay. Anyhow, you do need to disassemble your Roomba further and clean everything with 90%+ isopropyl alcohol. Besides cleaning things, it will also displace the water. Since you are dealing with electronics and a battery, try not to use to much water other than on the plastic parts maybe. Anyhow, start with these guides iRobot Roomba 650 to work on it. After it is cleaned you most likely want to get a new battery and then re-evaluate your Roomba.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brett Harling さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 4,635
