メインコンテンツにスキップ
Nintendo DS Liteは、ニンテンドーDSの後継モデルとして2006年に発売されました。このデバイスの開口作業は簡単で、修理もシンプルです。
316回答 すべてを表示
How can I fix a DS Lite that does not maintain its top case position?
I would like to repair my old DS Lite that felt on the ground many years ago. It still works but now it has a hole which reveals its hinge. The problem is that when I open the DS Lite to play its top case won't stay in position, infact I can't hear any "crack" that usually it does when the top part locks to stay in that specific position.
Which parts have I to buy to fix it?
Here are some images:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi @dadeaka ,
It looks like the upper case will have to be replaced.
Here is a link to the ifixit Nintendo DS Liteの上部ケースの交換 guide, which should be of some help.
Here is a link to a supplier of parts for the device. (scroll to the bottom to find upper case parts). It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Good luck finding a screwdriver that small! Lol
さんによる
Hi,
I might have the last laugh
Tools required:
Phillips #00 Screwdriver
Tri-point Y1 Screwdriver
さんによる
Can I just ask, when the OP says the top case doesn't stay in position, do you mean it is really floppy? My DS has no resistance at all to keep the screen in place. I just wondered if replacing the upper case will resolve this issue too? Thanks
さんによる
コメントを追加
Nintendo will fix it for free. The thread is a bit old, but you should call Nintendo support and ask.
https://www.engadget.com/2006/07/21/nint...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dade Aka さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 2,562
