It has a cracked screen. How do I fix it?
My kindle 4 will not turn on and has a cracked screen. HELP!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@dancey to replace the screen use this guide Kindle 4 Screen Replacement As for not turning on, that could be caused by a bad LCD, bad power adapater, bad battery or bad charging port. I'd try a new battery first. You can use the first guide for that as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 753
1件のコメント
Thanks so much! All worked... However the actual kindle is bent slightly. Will this affect it?
Emily Dansville さんによる
