メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
423回答 すべてを表示
When I shut down my MacBook Air it shows my desktop wallpaper.
Every night before I go to bed I shut down my MacBook Air. It relatively new, I got it for Christmas a few months back.
However, when I go to shut it down, sometimes it shows my desktop wallpaper and even part of the dock instead of an all black screen.
I'm kind of concerned since my laptop is pretty new, but is this a big issue? How can I prevent it and is it broken?
It only does this on occasion and it scares me a bit. I'm not sure why it's doing this.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
maybe you problem in software
さんによる
コメントを追加
4件の回答
最も参考になった回答
This sounds like Screen burn.
Although maybe your mac is just refusing to shut down completely. Try holding the power button down until it shuts down. (make sure you save, as this forces the shutdown)
could you add images so we can see what it looks like?
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I don't think it's screen burn - it kind of freezes on my desktop (I quit every app manually before shutting down)
さんによる
could you add an image of the leftover image after shutting down fully?
さんによる
It's just my laptop desktop background which is the Apple Yosemite 4 background and it shuts down normally other than the fact I can see it, it's not screen burn though. I can try next time it does it.
さんによる
if you disconnect the battery and power cable is there still something lef over?
さんによる
コメントを追加
I have this same problem. We’re you able to fix it? Or did it lead to any other issues with your Macbook?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem too :( how do you fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem with my new Mac book pro. I bought it recently and after reading some articles I found that deleting cache might help, cause I think the cache that has been collected creates a lag or slows the Mac down. So I highly recommend using a third party app cleanmymac 3 but to delete all the accumulated cache you have to buy the app as their is a limit of some mb or gb that can be deleted another way is doing it manually. My situation improved a lot so I'm planning to delete the cache manually as buying the app itself is something I left as option B. And you can surf the internet on how to delete the cache. Moreover, copy all the files before deleting because it may cause some issues and if their is an issue simply paste those files back to cache folders. Try opening all the folder one by one and deleting the cache rather than deleting the whole folder.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Morgan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 2,645
