メインコンテンツにスキップ
Wii Uはハンドヘルドデバイスとペアになったゲームコンソールです。ユーザーは、GamePadでゲームをすることもできます。コンソールの修理は簡単で、デバイスはほとんどがモジュラーです。
191回答 すべてを表示
How can I fix the disk drive?
So, I was taking apart the disk drive from my Wii U because I was curious as to what it looked like. I had no game inserted. I put everything back together to make sure everything worked. After inserting a disk, I powered it on, and everything was fine except for the disk drive. I couldn't eject the game from it, and it was making a sort of scratching sound. I turned it off and tore it back down. I decided to not take the drive apart except for the top covers because I didn't want to damage the game. Can someone please help?
Edit: I do not have a JIS screwdriver bit, and, once I get enough money, I'll be able to purchase one of the ifixit kits.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
My best suggestion to you is to tear it down and reverse it step-by-step using the iFixit teardown guide to see if everything you have matches.
Nintendo Wii U Teardown
Otherwise you are looking at about $25 for a whole new drive.
https://www.ebay.com/itm/Disk-Drive-Repl...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
William Sanborn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 599
