メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentが製造する家庭用ゲームコンソール。PS4としても知られています。2013年2月20日に初発表され、2013年11月15日に発売されました。
Why wont my ps4 show up on my tv?
My ps4 hasn't been working for two days. I have tried 3 different HDMI cables, two tv's and it still wont work. Safe mode isn't coming up but my tv does recognize its connected to a playstation. Their is also sound coming through my headphones when connected to my controller. The light shows itstarted properly (blue light then white light). what should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 78
66 件のコメント
When you say safe mode isn't coming up, have you attached your controller to the PS4 via a usb cable? As that is the only way to get safe mode to start.
さんによる
I had the exact same problem. I unplugged the ps4 for 24 hours and connected the hdmi into another port before turning it on. It worked! I then powered it off and then connected the cable back into the original port and it still worked. Not sure if it had something to do with the amount of time I had it unplugged or if it was switching ports.
さんによる
My question is, my ps4 does this but only for one tv that I own, I’ve hooked up other things to the tv via the same HDMI cable and port and they work perfectly, I’ve also hooked up my ps4 to another tv in my room with no problems via HDMI so I know it’s not my ps4 either
さんによる
Mine suddenly started doing this also !!
さんによる
I have the same problem, but you have solved the problem.
さんによる
61件以上のコメントを表示
コメントを追加
12件の回答
ベストアンサー
Sounds like an HDMI port problem. This is very common with Ps4's, especially the older ones. Sometimes you can shine a flashlight into the port and see the bent pins. If the port looks good it can also be the encoder chip on the motherboard.
このアンサーは役に立ちましたか?
スコア 30
31 件のコメント:
if it's the encoder chip how do we fix it?
さんによる
To fix them you have to heat them until the solder melts, then place the new one in its place
さんによる
How do you fix the bent pins ?
さんによる
thank you for this. It helped me so much
さんによる
fellas, this is happening to me right now, and i tried different hdmi and nothing works , im really not good at thoose things and dont want to kill my ps4 buy shoving a fork inside his HDMI port. what can i do?
さんによる
26件以上のコメントを表示
コメントを追加
Connect the hdmi cable turn on the tv but not the ps4, Now Pres and hold power button for at least 7 secounds until system beeps twice.
This worked for me so i hope it hepls you too
このアンサーは役に立ちましたか?
スコア 27
16 件のコメント:
it did not work for me.How strange?
さんによる
What does this do? I’ve had to do this every time now to get it to work.
さんによる
Does not help AT ALL
さんによる
It doesn't work because it beeps twice and then turns off
さんによる
Ok so, I had the exact same problem, when you unplug your PS4 HDMI and turn and hold the PS4 power button for the second beep, it resets the PS4s resolution to 480p... chances are at one point or another you accidentally set the resolution to a high one than your tv can support... how I did that I have no idea and you problem don’t either. Your PS4 will then give you a menu to select an option from(one of them being adjust screen resolution). Hit that option and it will then prompt you to auto or manually set it... I just did it automatically and presto, it was set back to 1080p for the better quality. I instantly understood what was going on, if this doesn’t work for you, then sorry to tell you dude, but you’re gunna have to take it to Sony. Thanks for the help!!
さんによる
11件以上のコメントを表示
コメントを追加
Unplug the TV and wait 5 seconds..unplug the back of the TV not the outlet.. your welcome.
このアンサーは役に立ちましたか?
スコア 16
22 件のコメント:
This actually worked for me.
さんによる
This worked for me too!
さんによる
That worked for me thanks 😊
さんによる
Omg really bro!!! I tried everything and all I had to do was unplug my tv!!! 🤬🤦‍♂️🤣. Man ty!!
さんによる
Thanks my guy!
さんによる
17件以上のコメントを表示
コメントを追加
Experienced this issue multiple times and these following steps seem to remedy the situation every single time.
  • Make sure to have both your tv and PS4 (PRO) powered off.
  • Make sure to have the HDMI-cable not connected to your PS4
  • Power-on your tv and set it to the corresponding HDMI-channel
  • Press and hold your PS4 (PRO) power button and wait for the second beep to occur (this will enable safe mode)
  • After you hear the second beep, connect your HDMI cable to your console
  • Safe Mode will then come online, make sure to check for new updates (i found out that this issue tends to come up everytime Sony pushes a new software update).
  • This update should remedy the situation, the console will most likely boot up a few times afterwards. Don’t cut the power on this boot sequence.
  • Afterwards the problem should be resolved. If not, go back into safe mode and check your resolution. Put this on 720p just to be sure -> you can always change it back to your preferred resolution when the console is fixed via Options -> Sound & Screen.
Hope this helps someone out there. Cheers!
このアンサーは役に立ちましたか?
スコア 6
9 件のコメント:
I dont have ps4 pro i have the regular one
さんによる
I only have the regular ps4
さんによる
I've been using an analogue converter for an old tv, and the HDMI would work on others.
Now it only works through the converter. And I can't get the safe mode to trigger.
This is rediculous
さんによる
Safe mode isn’t coming up on mine either so then what?
さんによる
This worked for me! Thank you so much
さんによる
4件以上のコメントを表示
コメントを追加
None of these have helped fix my issue. i’m going to have it tested at Game Stopthis morning. And if they can’t find the problem, then I am just going to buy a new one. I have tried everything on this page. And nothing works. My ps4 is not a Pro. It’s the Uncharted 4 edition game system. I’m guessing it’s because I’ve had mine for about 5 years and it is just worn out. We went to my sister in law’s and I hooked it up to her TV. We lost power at our house bcause of the tornados here in West Kentucky. It worked fine at her house. Then when we got back home, it won’t connect to the TV. I tried it on my other TV and it won’t work on it either. Lesson learned. I am not going to take my ps4 with me whenever we have to go somewhere else to stay. Lol
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Mines is old too😭I went to go plug in my ps4 camera and I picked up my ps4 to plug it in and it just disconnected from the tv
さんによる
コメントを追加
I've had my ps4 for 2 or 3 years and suddenly it stopped working. It switches on but the TV says 'no signal' and my controllers blink white. I don't even know if it's a pro or not but considering none of these options work, it might not be. I can't repair it at shop because HK is having a lock down soon so electronic stores are closing down temporarily. Not to mention I need the money for it. Which I wager it won't be cheap. So is there really no way to solve it?
I doubt I'll get a quick answer since this page hasn't been updated with responses in a long while so I'll probably copy and paste this on reddit somewhere. Still, I want to find answers as fast as possible.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi, during the last few weeks I tried all the ways found on the web but without success. Finally today I solved the problem using a hdmi switcher with the hdcp bypass (an adaptor that allows you to connect a device to two screens)
さんによる
Hi Giack, do you have a link to the specific switcher you used?
さんによる
@zurich46825 Yes, i just found it. I bought it on Amazon.
https://www.amazon.it/gp/aw/d/B00LCUJX9G...
さんによる
コメントを追加
Ok this has worked for me but it actually took longer than expected! I did the safe reset ( turn on the PS4 and keep holding the button for approx 10 seconds until you hear a second beep, then connect DualShock with USB ) and it didn’t work so I gave up and left it for like 5 min and then suddenly it connected to the TV! So you might want to give that a go
Good luck
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My brothers say that they’re trying down PS4 services but they’re not because my Foster mom searched it up and they said no
さんによる
コメントを追加
I still haven’t gotten mine to work. It fell it it’s topside and since then hasn’t given a display. I have booted it in safe mode and hard reset but it still hasn’t given a display. I know the HDMI cable works because I use it on my Xbox and I’m using the correct input. Please help me
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Right so basically everyone still reading this is sad get it repaired for 100 pound that’s nothing
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
For a ps4 that's worth 199 whats the point of spending 100 to get it fixed when at that point u can buy a new ps4. That's why I haven't brought mine in the shop yet. I'm trying to find a cheaper option to solve the problem than paying someone that much to fix it when it's just worth getting a new ps4 then.
さんによる
コメントを追加
worked for me as well thanks bud 👍
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Worked for me thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are they are they not?
It shows I’m wondering because I have a PS4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ali Naqvi さん、ありがとうございました!
統計データ:
過去 24時間: 30
過去 7 日: 325
過去 30 日: 1,589
今までの合計 705,698
