メインコンテンツにスキップ
締切られた回答
Power light and fan are on. display and hard drive not working?
Problem:HP G60-535DX Computer shut down by itself. When I tryed to restart the computer the only things that came on were the Power Light, Bluetooth Light and the Fan. The Display is Black like it not getting a signal. I don't think the Hard Drive is running(I can't hear it). I tryed hooking to a external monitor and a hard reset and that didnt work. Would a bad Hard drive cause these problems?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There's two possible solutions to your problem... the first is that the screen died on you and you'll need to replace it... the second is that the motherboard has got a problem with the CPU and/or GPU, and since you cannot replace them, the only solution is to replace the motherboard. If your laptop is still on warranty, the best thing to do is have HP fix it, but if it's not on warranty, then take it to your technician and them work on it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 851
