メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
423回答 すべてを表示
My MacBook Air won't turn on?
After working completely fine one day, my macbook air suddenly refuses to turn on. The charger light is orange and works fine, I tried an SMC reset and the charger changes to green for a second then reverts to orange as expected. I have also tried disconnecting the battery and then reconnecting. I have also tried holding the power in for 10 then plugging in the charger while holding the power button. Nothing seems to work!! I really appreciate the help and thank you very much in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The MagSafe charger only shows Amber when it's charging the battery. Once the battery is charged it will go Green. If it never goes Green you likely have a bad battery.
As your system should still be under warranty (2017 models one year in parts) I would recommend you go to an Apple Store and have them deal with it.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The light on the charger recently changed to green indicating that it is most likely not a battery fault.
さんによる
Not Good ;-{ Then your logic board in trouble. Still go to Apple!
さんによる
コメントを追加
回答を追加する
Mitchell solomon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,278
