メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Multiple Battery/LCD combinations won't work.
Hi all!
Long story:
My parents sent me an iPhone 6 my mother used to use. The screen was cracked, the LCD was having issues, and the battery was acting up. When I first plugged the phone in to charge I was left on the battery symbol against the black background with a sliver of red for 15+ minutes indicating it was charging, but I don't feel as though it really was. When unplugged, the screen displayed a charging cord underneath this battery, obviously indicating it needed to be plugged in. I figured a new batter would fix this issue but to no avail, now that the battery and screen are both replaced, I am no longer getting anything on the screen. Multiple battery / LCD combinations have given me the same standstill of the phone not turning on or showing any signs of life. Plugging in the charger in any of the scenarios yielded no results either. What could be the issue and how can I fix it?
Long story short:
1. iPhone 6 had Screen issues and Battery issues.
2. When plugged in for any length of time, battery did not seem to be charging enough to turn on before repair.
3. After repair, no response on screen at all, even when plugged in.
4. No screen / battery combinations have seemed to be working.
5. What do?
P.S. Yes, I know to unplug the battery before unplugging the screen for repair, and the parts were ordered from my store's (iPhone repair store) distributor as premium parts.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It sounds like it could be a Tri-Star issue, the charging diode on the motherboard isn't allowing it to take charge basically, generally this allows it to charge when its turned off but when it turns on you cannot charge it anymore. It also takes an extremely long time. Unfortunately the only way to fix it is to replace the actual chip on the motherboard, i have done a few of them with success but they aren't very easy.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Where would I find this piece for order and instructions on the repair? I'm relatively experienced with small tech repairs so I may be able to do it if I can find a good instruction source.
さんによる
http://www.microsoldering.com/software/
The parts are extremely small, i use a very good scope to make it easier, i don't think you'd be able to do it with just the naked eye. My supplier gets me the parts i need, i am not sure where you'd be able to get them, eBay maybe?
さんによる
コメントを追加
回答を追加する
Xander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 30
