The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Alison McCaulley @allydawn
評価: 1
投稿日: 2018年2月23日
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
この質問は役に立ちましたか?
sm_vulkus @vulkus
評価: 2.7千
5
4
投稿日: 2018年2月24日
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 136
