メインコンテンツにスキップ
The LG Xenon GR500 is a QWERTY keyboard cellular phone with a camera.
1回答 すべてを表示
Why are my texts displaying in the wrong order?
I recently started using a new LG GR500, and i noticed an issue of the texts not displaying in the correct order. When i text someone, all my texts are on top, and theirs are on the bottom. in other words, they are not displaying in chronological order. i have looked this up and other people with other phones have had this problem, but just switching the automatic date and time off then on worked for them but that did not work for me. i have also tried a factory reset and master clear and master reset, none of which worked. it quite obviously sounds like a software glitch. does anyone know of a fix for this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Someone posted a similar statement with the phone you have. Apparently it is common, and one of the fixes is the calendar. Check the date and time and make sure it's current. The last option, from the carrier, was to master reset the phone under reset settings.
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
all good except- you forgot to mention where it came from with a link. worthy of an upvote from me either way.
さんによる
The link was not a guaranteed solution, so I did not bother because it's more of a theory.
さんによる
still, the answers may help. but I see why you did not. I'm not going to force you to include the link because if you're like me you probably lost/forgot the link.
さんによる
no. That's why there is a history in the browser.
さんによる
Oh yeah... Forgot.
さんによる
1以上のコメントを表示
コメントを追加
Are you on good wifi? I remember this happened to my iPhone and stopped doing that after going back onto my home network. (texts did not return into the correct order, just stopped putting making new ones in the wrong order.)
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
This phone is from 2009, so it actually doesn't have Wifi capabilities!
さんによる
cellular then.
さんによる
well, in that case, my cellular connection is fine. it isnt like the happens on and off, its just constantly like this no matter my connection
さんによる
コメントを追加
回答を追加する
Randi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 163
