メインコンテンツにスキップ
パナソニック DMC-FH25K 16.1MP、8倍広角手ブレ補正ズーム、2.7インチLCD搭載デジタルカメラ
My LUMIX camera us stating “System zoom error”
I found my camera which I haven’t used in years. I charged the battery and put it in the camera. When I went to put it on it says set clock and then goes to system zoom error. I removed the card and battery for 10 minutes and replaced them both. The same thing happened.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
ademas de marcar el mensaje de error, el lente (zoom) no sale, podria aconsejarme que hacer?
さんによる
I tried to do the same thing to my camera and did not work :( What else can I do?
さんによる
My camera is a DMC-TS20 please help. Keeps saying Zoom Error when I turn on.
さんによる
Thanks, used a little cooking oil on a paper towel.
さんによる
コメントを追加
2件の回答
ベストアンサー
I had the same issue. I read on one of the help sites to gently but firmly bump the side of camera with the palm of your hand as you turn it on. I did this and the lens un-jammed. I then sprayed Teflon spray on a clean cotton cloth, extended the lens completely and GENTLY pulled it out another half inch. I then wiped all sections of the lens barrel with the Teflon coated cotton. I waited a couple minutes for the Teflon to permeate the plastic barrel then wiped any excess off. The lens works perfectly now and every time I turn it on or off, it extends and retracts as well as ever. May have been a moisture issue, or granular dust, but it’s clean and working well.
このアンサーは役に立ちましたか?
スコア 12
8 件のコメント:
My camera literally hasn't been working for about 3 or 4 years. The lense was stuck extended and the w park was open. I just did the hitting it against my palm while turning it on and it worked. Thank you so much
さんによる
Like wise to the above scenario haven't used the camera for over 10 years - followed instructions and wella it worked ..thank you
さんによる
i did this and it worked! thankssss
さんによる
Thank you, I've had this problem since visiting Kew's Orchid Festival in a humid glasshouse.
さんによる
I did this about a dozen or more times along with the Teflon treatment and it is now working.
さんによる
3件以上のコメントを表示
コメントを追加
@nancydonald "then goes to system zoom error" possibly a stuck lens. Let us know if your camera is a FH25 or FH27. If you an, check to see if there is an error code in memory. For that do this:
Error Code Memory Function
1. General description
This unit is equipped with history of error code memory function, and can be memorized 16 error codes in sequence from the latest. When the error is occurred more than 16, the oldest error is overwritten in sequence.
The error code is not memorized when the power supply is shut down forcibly (i.e.,when the unit is powered on by the battery, the battery is pulled out) The error code is memorized to FLASH-ROM when the unit has just before powered off.
2. How to display
The error code can be displayed by ordering the following procedure:
• Preparation:
1. Attach the Battery or AC Adaptor with a DC coupler to the unit.
NOTE:
*Since this unit has built-in memory, it can be performed without inserting SD memory card.
• Step 1. The temporary cancellation of “INITIAL SETTINGS”:
While pressing “W side of [ ZOOM LEVER ]”, [ SHUTTER BUTTON ] and touch the screen (Any position of the screen is acceptable) simultaneously, turn the power on.
• Step 2. Execute the error code display mode:
Display [ Version Disp. ] screen in the state of Step 1, and then move the [ ZOOM LEVER ] to “W” side.
The display is changed as shown below when the moving to W side.
Version Disp. → Error code display → Operation history display → Version Disp. → .....
If you have an error or multiples, give us the error code number etc.
Here is the manual for the disassembly of your camera in case you need to replace the lens unit FH27-Disassembly.pdf
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks, problem solved by tapping the lens as i zoomed.
I will look for the teflon additional precaution to keep it running smoothe.
Martin
さんによる
コメントを追加
回答を追加する
Nancy Donald さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 107
過去 30 日: 440
今までの合計 31,268
