メインコンテンツにスキップ
Arport Etreme card not detected?
I have installed airport extreme card into my iMac and it does not recognize it. (I think that the Airport Extreme card has bluetooth)I need the bluetooth,to be able to use a Magic Mouse and Wireless Keyboard. I guess I could use a dongle but I don't think that will wake up the machine, and since I installed the card would like it to use the WiFi as well. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
See if the card is seen in your System Profiler. If so then run software update and see if it downloads airport software.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
I checked System Profiler, I am not sure what to look for but I don't see anything about an Airport Extreme or WiFi or bluetooth.
さんによる
go to about this mac > more info > Network > Airport and see if it sees anything
さんによる
OK I found the Airport Extreme card listed with related numbers and info but it says it is turned off, how do I turn it on?
さんによる
I just checked for updates and nothing helped, I updated Itunes, and a couple others but nothing helped the airport. Thanks for any help, I appreciate it.
さんによる
Go to your hard drive > Applications > Utilities > AirPort Utility and run it.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,107
