メインコンテンツにスキップ
様々なグラフィックカード
111回答 すべてを表示
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
hmm noone?? :)
さんによる
コメントを追加
4件の回答
最も参考になった回答
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
its not the same
さんによる
コメントを追加
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
さんによる
i would only be guessing as theres no schematic i would probably try 0603
さんによる
most r200 is see are 1w 1% so any resistor around that
さんによる
where i can get that...0603 r200? :)
さんによる
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
さんによる
1以上のコメントを表示
コメントを追加
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@hendricorico no, it is not a fuse.
さんによる
コメントを追加
@xuw here it is almost 6 years later and I am certain you have replaced your video card by now. Just for completion sake, check the reference designator on the PCB
. It says B200 and MB200, so it is not a resistor. It is a ferrite chip bead inductor. In this case it has a impedance of 220 Ohm 2500mA 25% in a 0603 package
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ole さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 12
過去 30 日: 44
今までの合計 3,500
