Why is the tablet stuck on the screen saying nextbook powered by andro
It is stuck on this screen won't shut down of this screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I will try to help. Try to open it up take the battery out and re connect it. If that dose not work try to get to the bios setting by clicking the power button and volume button and then go to reset. I am not an android user but I don’t know if it will delete your info if you go into bio settings. But try it. Good luck.
このアンサーは役に立ちましたか?
What if i cant do any of that then what
Umm I found this link from the internet.
http://www.tomsguide.com/forum/id-305219...
You can try to reset it again I am sorry that I can’t be more useful. Hopefully you will get it to work. Also did you call the company that made it. If not try giving them a call.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 19,254
3 件のコメント
Tried both nothing
David さんによる
My tablet keep getting hot an stuck freezing what is wrong withit
Emma Green さんによる
My tablet is just loading on the screen that says nextbook
Zacorra Johnson さんによる
