メインコンテンツにスキップ
Portable wireless speakers from Logitech released in 2013.
70回答 すべてを表示
Defective jack port on Megaboom
Hi,
I just bought the limited Big Black Dragon edition of the Megaboom.
It works perfectly as a Bluetooth speaker but there's a problem with the jack port.
The sound only comes from one side of the speaker. If I want normal stereo sound, I have to hold the port of the cable slightly on the right. I tried with 3 different new 3.5 stereo jack cables, same result. There seems to be an issue with the port itself.
Do you know if there's a way to fix it by myself? I don't want to return it to the store since the Black edition is very limited and I'm afraid they will give me another regular version as replacement.
Thank you very much for your answer/help in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
Im not sure now is the connection, it seems that it can be detached, take pics of it, how it is connected to the mainboard.
you might need something like this, and desolder out / splice and solder in the new one
https://www.ebay.com/itm/10-Pcs-3-5mm-Fe...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thomas Hubert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 95
