メインコンテンツにスキップ
電子タバコはこれまで通例だったタバコに変わり、再利用ができる吸引機です。
121回答 すべてを表示
T priv 3 300w won’t charge?
I just got my Vape yesterday and I’ve tried the charger it came with and about 10 different ones what should I do? It doesn’t even show a charging symbol or anything I’ve left it on charge for at least 2 hours on each charger and it still says battery low needs charged
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
13件の回答
最も参考になった回答
If you have a T-Priv 3 Mod, the cable that came with it is NOT the charger. It is a data transfer cable that you can use to update your T-Priv 3 by connecting it to your computer.
The [3] batteries need to be removed from the T-Priv 3 (by opening the battery compartment on the bottom) and charged using an external battery charger (not included by Smok).
Hope this helps! I just got my T-Priv 3 a few days ago and am currently charging my batteries, so I feel confident that this should solve your problems.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Thank you I just had same proble. What does it update
さんによる
is there any way to make it charge with USB? its really frustrating because i bought an external battery charger but it doesnt work.
さんによる
hey how do u transfer the data and stuff i tried a normal samsung charger the batteries r samsung as well and they aint charging idc if i need to do the data transfer or not but idk i think it could be fualty
さんによる
I just bought the t-3 3 battery's it turns on then when i turn it back on it goes to BLUE then shows a flashing red like it's not charged and i have new batteries and charger-- HELP!
さんによる
I did what you said but it keeps going to charge batteries and i just bought 3 new one's today and the others are less than 2 months old
さんによる
コメントを追加
idk i think its bssssss
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It’s a 3 battery vape it won’t charge off a cord you need a battery tray charger
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
But. 18650 which I got for the vape arnt rechargable. So would I need to get batteries as well.
さんによる
Seriously? Stay away from your device.
さんによる
コメントを追加
Is there anyway I can charge it trough usb because buying 3 rechargeable batteries and a charger is expense.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's not good for your batteries. Each battery is about 6 on a few websites. A dual charger less than 10. Why cause a possible battery short? Plus the amps are so small from the device it would take hours
さんによる
コメントを追加
it is not a problem it doesnt support charging from mod i have the issue of screen failiure cant find smoks response to this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So !#^&@@!! The guyat the store told me i could charge it but i might want to invest in batteries sometime to make it charge better. Nd i bought it. F#ck him
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The USB port on T-Priv III can only be used for firmware update, no charging is accepted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is there a place i can send it for repair. as it’s been a problem sense the day i got it 2 months ago
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how do i bar scann it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey all you guys !
This is very important!
The only batteries that should be used with any vape device are the extremely high drain current rated ones. ESPECIALLY for low ohms use .
18650 lithium rechargeable rated at 35 ,or at LEAST 20 Amps are probably what you should be using for the Smok T Priv 3 . Especially with the sub ohm coils . Its Dangerous to use batteries that arent high current drain rated , they can explode or catch fire …...
Its an awsome mod , but you do need a charger to charge the batteries , I always have 3 extra batteries ready to switch while charging.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You should have been told when you bought it that you have to have a charger to recharge the three 18650 batt. that you also have to purchase. the USB cable is not for charging but for programming only.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I honestly think that somewhere in the description of this product, it should have been made clear that you need an external battery charger. Every other mod that I’ve had has been able to charge via USB. So naturally I assumed this one could as well, which is the exact reason I didn’t buy a new port charger in the first place. However, it should also be understood that charging 18650 batteries with a USB, such as the ones the T-Priv 3 takes, is very dangerous, with chances of batteries catching fire or even exploding. In all honesty, buy a quality 4 port battery charger, very worth it and saves a lot of time, as well as much safer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most vapes these days don't support onboard USB charging, ridiculous I know! I've not really had the inkling to search out what the USB port IS for…so unfortunately you're going to have to shell out a few more bucks for an 18650 charger.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ethan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 18
今までの合計 38,080
