メインコンテンツにスキップ
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
LCD ribbon cable connector missing
The black clip that holds the LCD ribbon cable snapped.
Is there a way to replace that piece and what is the part number please?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
To replace the clip requires microsoldering . iIt may be easier to try to repair the clip if its not badly broke . the locking mechanism is held in place by two small nubs at each side of the clip that go into the side of the base . if the nubs arent broke off you should be able to get the clip to go back on . use a pair of tweezers and it may help to have a magnifing glass to see what your doing . If this brings no joy you can also try wedging a small piece of plastic into the joint to force the ribbon cables down onto the pins then taping everything in place . If however you want to solder on a new clip you may want to take it to someone who does this kind of work . Hope this helps
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
Do you know I could purchase the clip?
さんによる
The black clip is what is missing. The terminals on the ribbon cable face upward so I would to put the shim (?) under it to make the terminals make contact.
Any ideas on what would be best to use?
What type of tape would you recommend ?
さんによる
piece of plastic from a guitarpick or credit card will work you will need to see what works best just dont cover the pins , as for tape black electical tape will work or kapton tap can also be used but nothing conductive . As for places to get parts I use digikey.com ,AliExpress.com, dhgate.com Ebay and Amazon to fined what i need
さんによる
I had the exact same problem, stuck some tape to bottom of lcd cable at the end so it made it fatter (so it lifted it up) this made contact now display is working
さんによる
Is there any guide on how to replace the lcd flex cable? How on earth do u disconnect the other end? Does the screen have to be removed?
さんによる
4件以上のコメントを表示
コメントを追加
Yes I have to agree with the method of placing black insulation tape on the back of the main ribbon.
Ensure not to overlap the edges.
I used one piece on one tablet on another I had to double it up with two pieces Once screen is active hold the ribbon in place with some tape going across the battery to keep it in place.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I hadn't read this solution before reaching to the same conclusion today. I had to open the tablet as the LCD cable had become loose. During this process I broke the black plastic clip and then the LCD cable wasn't making proper contact. Just a bit of tape under the cable, some more tape over the battery to secure it and now it's all good again
さんによる
It will be better to have a youtube videos explaining it...badly need it
さんによる
Can't find videos
さんによる
コメントを追加
回答を追加する
D Brown さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 33
今までの合計 7,039
