My left wheel is making a noise when I drive more than 20mph
I ran over a speed bump and my left wheel is making a noise like it's rubbing against something when I drive more than 20mph
Could be it's got a dent in the wheel now? If you can get it off the axel easily enough it might be worth a look. I hit a pothole once and it was a bit like that.
このアンサーは役に立ちましたか?
As Jack said, it could be a dented wheel, or the knuckle joint could be damaged (worst case scenario)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 7
今までの合計 187
