How do I replace the hardrive on a PowerBook G4 Aluminum 17
how do i replace the hardrive on a PowerBook G4 Aluminum 17
この質問は役に立ちましたか?
この質問は役に立ちましたか?
For the 17in model A1139 high resolution display PowerBook G4 use this guide: PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Hard Drive Replacement
For the 17in PowerBook G4 models A1013, A1052, A1085, or A1107 use this guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Look at the underside of your powerbook there should be a small label printed onto the aluminum which will tell you what model number you have. I hope this helps, good luck!!
ガイド
難易度:
中レベル
25 minutes - 2 hours
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 774
1件のコメント
What's you processor speed? There are five different machines that meet your description.
mayer さんによる
