メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Two Fuzzy vertical lines & Unstable touch functionality
Hello...
I'am facing an Occasional two fuzzy vertical lines and some unstable touch functionality like ghost touches and unresponsive screen,However, when the two lines appear the touches seems to be working perfectly except for the region where the two lines , when the two lines are not appearing I may face a ghost touches and unresponsive screen, only in the right side of my screen, moreover, the adhesive stripes of the battery i guess they are not working anymore because can hear the battery moving in it's housing, and also the front panel covering the LCD connectors with the board is missing...
I'am 60% sure that this is caused by the Electric static charges from the battery..
can the Iphone 6 series have such electric static charges problem?
What do you think should i do to fix this?
Update (02/13/2018)
update:
So I've tried to re connect the LCD, I faced some problems like :-
1- After reconnecting the 2 Lines at the right side disappeared, instead many other fuzzy lines appeared,
Fix: just disconnected the LCD and cleaned the Flex cables and reconnected again, the lines seemed fuzzy then but i guess they will disappear after recharging.
2- The main problem is, Now i have a vertical area where the touch is fully unresponsive, No more ghost touches but there is a vertical area where the touch is unresponsive..
any ideas??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like a faulty screen, you should get some double sided tape adhesive like Tesa 4695 or PET Red double sided tape which you can find on ebay to keep the battery in place.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Should this solve the electric charges problem ?
さんによる
I don't think ESD (eletrostatic discharge) is the issue here, it's probably just a faulty screen.
Have you tried reseating the screen cables? Make sure you unplug the battery first before you do so.
さんによる
コメントを追加
回答を追加する
Omer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 499
