メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why my iPhone7 after charging dons't work again?
Hi there
Device: IPhone 7 Red 128GB
IOS: 11.3.3
Model: A1778
#the problem:
After the power outage of the battery as normal ..
I connected the iPhone to the charger (from Anker)
Then the charger icon works ...
While waiting for the apple screen to start operating, the power suddenly went off and the phone did not work after it
I have repeatedly tried to pair with iTunes but not to use it, a dead phone
I tried to enter the DFU and the back position
But there is no response
You also reconnect the cable to the battery by opening the device and removing the cable and then reconnecting it, also not useful
Does anyone know the solution to that?
Has anyone encountered the same problem?
#The following attempts were made to turn on the phone and all did not work:
  • DFU
  • Recovery Mode
  • Open the device and disconnect the battery and reconnect it again
  • Try and recreate what was previously done with the iTunes using the original Apple cable
Also still after those attempts .. does not work !!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
So tl:dr probably tristar chip needing microsoldering replacement if the apple logo does not appear with the battery unplugged but charger plugged in.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello, DFU & iTunes will not works if battery is empty at all!
So, looks like you need to charge battery first.
If battery is empty at all then better use original(sometimes MFI may works) Lightning cable with original Apple charger for your device, or connect it to Mac USB port and wait! Wait for few hours minimum to 24h, if device is OK usually it start charging, if it do not show charging icon anyway wait for 24h. If it not powers up anyway, then try iTunes or iTunes&DFU to recovery iOS.
If it not helps, then battery may be locked and you need remove it and activate with Battery Activation Tool and charge it with Lab PSU or Smart charger or replace battery if it dead at all.
Here is a video how to do that -
Or power up logicboard with iphone 7 dedicated power cable to be sure it works correct, cable like this -
This cables and battery activation(charging) tool cost few bucks on eBay.
If battery OK then problem can be in Lightning connector - try to clean it with alcohol.
If not helps then it can be flex cable to logicboard from Lightning connector or logicboard issue(usually Power Control IC 610A3B), here it is -
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mohsen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 136
