メインコンテンツにスキップ
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
214回答 すべてを表示
iPad randomly restarting and WiFi grayed out
Hello, my problem is my iPad will randomly reboot, when it comes back on the WiFi will be grayed out and I am unable to turn it back on. Only after several restarts does it work properly....for a little while. I have already replaced the WiFi antennas and factory restarted it so that can’t be the problem. The problem started when I tried to use my aunts charger on my iPad, a charger that I didn’t know was a fast charger, my theory was that it overloaded the iPad with power. Don’t know if that’s the case but what ever it is, how can I fix this?? Thank you in advance for any help you can provide.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I have the same problem with an iphone 6, I also replaced the antenna and it’s doing the same... In my case, my phone got a little wet from the rain, and it started to behave this way, so maybe an overshoot in current is causing it... were you able to fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steven さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 310
