メインコンテンツにスキップ
My Logitech Wireless M325 isn’t working.
Hi my Logitech Wireless mouse isn’t working. I’ve replaced the battery and doesn’t work. It’s a new battery cause I’ve tried with a couple different battery’s. The green light doesn’t turn on when I turn it on.
Model number: M325
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
11 件のコメント
Hi @paperboypaddy ,
Have you checked that the switch is working? (use an Ohmmeter to verify)
Have you checked that the battery connection terminals are exerting enough pressure on the battery when it is in to ensure a good connection.
Have you checked that the battery connection terminals are still connected to the pcb and haven't come loose or broken off? Again use an Ohmmeter if you have to.
Also it is "batteries" ;-)
さんによる
The thing is I’m not sure how to get it opened. So I can’t check the switch. I’ve checked the battery connectors and they’re fine.
さんによる
Download the Unifying software and try re-syncing. http://support.logitech.com/en_us/softwa...
Does the laser light up?
さんによる
@pccheese its a invisible laser mouse. So no the laser isn’t lighting up. ;-)
さんによる
@paperboypaddy Logitech darkfield mice don't have an invisible laser. There is still a red light you can see. Look
さんによる
6件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
A 325 is a newer model.
See if you still have the receipt.
If you do, it may still be under warranty.
If it is, Logitech will send you a new replacement mouse free.
https://support.logitech.com/en_us/conta...
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
@paperboypaddy also try downloading Logitech's unifying software to see if the receiver simply forgot the mouse it was paired with.
https://support.logitech.com/en_us/softw...
After you install, click "Advanced" and manually pair. It will tell you to turn off and turn on the mouse.
さんによる
@avanteguarde ok. I’m going to get a replacement then. I only need the serial number, no receipt needed.
さんによる
IT WORKED for me, downloaded and ran unifying software and BOOM the wireless mouse WORKS again, QUICK and easy
さんによる
コメントを追加
最も参考になった回答
Hi @paperboypaddy ,
Here you go. This should be of some help.
Also if you meant "they are" it is they're (as in ..... "I’ve checked the battery connectors and they're fine" not there). Remember Padraic, it's all about improving ;-)
このアンサーは役に立ちましたか?
スコア 5
15 件のコメント:
Grr thanks for pointing that out I would’ve never saw that. How about you tell me all the times I do that so I can improve. I kind of went right over it and didn’t notice that I did it. Also my iPhone may have auto corrected it for me.
さんによる
Hi,
I'll try but I don't get to see all your posts.
Keep it up.
You're definitely improving ;-)
Don't know if iPhones check for correct spelling with syntax. You spelt the word, "there" correctly, so the iPhone would not have picked up that it was the wrong word to use for what you wanted to say. You obviously meant to say they're. It's a trap that a lot of spell checkers don't cover.
It's like when I sometimes misspell the word "from" and type "form" instead, it passes the spellcheck until I notice the error and correct it.
さんによる
Oh you can just tell me if you see anything at some point. Doesn’t matter if you do it for all of my posts.
さんによる
The best way for me to get better is by checking the post a couple times before I post it.
さんによる
Hi @paperboypaddy ,
You catch on quick!
Cheers
さんによる
10件以上のコメントを表示
コメントを追加
回答を追加する
Padraic Hoselton さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 108
今までの合計 23,350
