Why does my picture turn off after 10/15 minutes but sound stays on?
My bush 42inch television has just started to turn the picture off after 10/15 minutes but the sound still stays on how can I fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
its possible that your back light is turning off either due to a problem with the power supply, inverter, or the lamps them selves. Try shining a flash light and see if you can see a faint image on the screen. that will tell you if it is the backlight.
このアンサーは役に立ちましたか?
We reset to first setting cuz someone said reset to factory setting and at the moment it’s staying on fingers crossed
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36
