My laptop screen black but my power button still on
i want to ask how i want fix my laptop presario CQ41 because my laptop screen black but my power button still on...so how i want to fix?
you can also check your RAM whether it has been damage
I also have the same issue with your own but later changed my RAM , everything come back to normal instantly .
このアンサーは役に立ちましたか?
Try getting a new charger or getting the charger panel replaced.
このアンサーは役に立ちましたか?
Technical Difficulties why would you suggest to replace the charger if you have not explained to the OP how to test it? What do you refer to as the "charger panel"? This laptop does not have a single part that is referred to as a "charger panel", so nobody will know what to look for.
Your answer is somewhat misleading due to your terminology and not very helpful with the diagnosis or repair of this issue.
Charging port. The thing that you plug the charger in. Whatever. Has charging in the name.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 1,015
1件のコメント
My laptop screen still on black colour and in every 5 seconds my laptop turn off and then turn on then it continue cycle until I remove the battery and insert it again
Lakshya Acharya さんによる
