メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Top Left Wifi Antenna cable repair
I was repairing an iPhone 6s plus with a cracked screen and sticky power button. While putting the logic board back in after fixing the power button I was attempting to put the top left antenna cable back in place when I noticed it was suddenly more loose. After looking over it I noticed the wire leading into the connector had come out.
After looking in the store and seeing the antenna is currently out of stock and I have a customer expecting a phone tomorrow I thought I would try my luck here. Other than getting lucky and find one somewhere else to buy, is there any tricks I could use to re attach the wire to the connector?
I don't currently have a micro-solder kit, so hopefully that's not my answer. Any insight by someone with this kind of experience would be very greatly appreciated. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It has to be re-soldered if you want a proper connection.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
This may be me over thinking it, but soldering a wifi antenna wouldn't cause any interference or problems with the phone would it?
さんによる
コメントを追加
回答を追加する
Repair-IT さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 116
