メインコンテンツにスキップ
The fourth generation of HP's low-cost, 11.6 inch Chromebook 11, released in 2015.
11回答 すべてを表示
Will Replacing Motherboard Unenroll from Enterprise?
I have this school enrolled chromebook and I graduated last year. I have been trying to unenroll it because my school IT guy never unenrolled it after I graduated. I have tried a lot of old ways of unenrolling and they all never worked. I was thinking maybe if I would get a new motherboard, there would be no data so I would technically be free, right?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
https://superuser.com/questions/811404/r...
Don't replace the mb you dont have to.
さんによる
コメントを追加
5件の回答
ベストアンサー
Replacing the hard drive would be easiest. If you remove the hard drive from the machine and wipe it clean, then re install it to the chromebook and restore the original software using the manufacturers website you should be good to go.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
HD is a chip on hp chrome books.....
さんによる
how would i wipe the hard drive after taking it out?
さんによる
you connect it to a pc and delete everything on it
さんによる
コメントを追加
Actually replacing the mother board is easy. Hard drive is firmware. As long as its not a replacement from the same school system yes you will be un-enrolled. Chrome administrator would have to be physically at your screen to enroll you……I am a tech at a school system who are 1 on 1…..Seems all i do these days is repair them.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Holly Wilcox-Cline but what if you can't unenroll it. I've tried multiple times and it can't be unenrolled.
さんによる
コメントを追加
I've tried looking for the hard drive but my best guess is that it is soldered into the motherboard, making it hard to remove if I was able to
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Depending on your Chromebook model it might use a WWAN card, my Dell 3100 does.
さんによる
Idk if you'll see this now but did it work?
さんによる
コメントを追加
I recently bought an hp Chromebook 11 g4 off of ebay and it has the same situation, so if i was to buy a new motherboard it would work?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yes it will work
さんによる
You dont have to go to that extreme...Just powerwash it and dont re enroll it...I work in a school system and do that all the time.
さんによる
Having same problem. MY Chromebook has a WWAN Card for a hard drive. I can buy a WWAN Card to USB on Ebay, if I wipe that will it get rid of Enterpise Enrollment? Or do I have to replace the motherboard?
さんによる
コメントを追加
By the way Powerwashing does not get rid of Enterprise Enrollment if developer mode is disabled.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Riley さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 53
今までの合計 3,008
