Uneven bands and the ear cup is st the wrong angle.
My headset band is uneven as in one side is longer than the other.
Haly “Haly” not sure what you mean the headband is longer on one side. You can adjust the aluminum arms on either side (part where teh driver (speaker) is mounted to. That should even this out. If there is anything else going on with it, post some images of it with your question. Use this guide iFixitでの質問に画像を追加する方法 for that so we can see what you see.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 182
1件のコメント
I have this same problem too. Basically one side of the headband is longer than the other and the 2 earcups are not aligned together. (One ear cup is higher than the other.) I've checked the whole headset and I can't find what's wrong with it.
Vincent Adeola さんによる
