メインコンテンツにスキップ
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49回答 すべてを表示
Won't charge while turned on and drops charge
I have had my OnePlus 2 phone for two years now. I haven't had any problems with it until recently. It was charging fine but now it won't charge right. I plug it in to charge and the charging light will come on but then it stops charging. The only way I can get it to charge at all is by turning it off and letting it charge that way. But once I have it charged to 100% and go to use it, it drops dramatically. Like for example it'll be at 100% and if I let it sit there and not touch it it drops down to 80% within 2 minutes. At first I thought it was the charger so I got another but it still did the same thing. I haven't bought a new cord as of yet.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
First try a different cord, just to prove that the cord is not the problem.
How old is the phone? I suspect that the battery is failing and needs to be replaced. Even rechargeable batteries have a lifespan.
Here is a link to the ifixit OnePlus 2 Battery Replacement guide.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Anna Trussell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 968
