メインコンテンツにスキップ
建物の広いエリアを照らす最もポピュラーな選択肢です。多種多様な接続方式と定格電力があります。
22回答 すべてを表示
lights not coming on right.
Hi,
I have two 4ft double bulb flouresent light fixtures in my Kitchn. I live right out of New Orleans, LA. When it rains, and it's damp outside we have trouble turning the lights on. Especially in the morning. Sometimes you can flip the switch on and off a few times and get it to come on. But most of the time you just have to wait.
Any idea what could be causing this?
Lee
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have this problem. . . is there an easy fix short of replacing the fixture? Can I use sandpaper or an eraser to clean off the connections (the round slot where the fluorescent prongs make contact?
さんによる
コメントを追加
4件の回答
ベストアンサー
When using fluorescent lighting in wet or very humid areas, it is important to ensure the bulb or ballast is grounded properly. Most modern residential electrical wiring incorporates an electrical ground into the circuitry. Whether using a traditional fluorescent with a ballast or a compact bulb, always ensure the fixture has been installed and grounded properly. Fluorescent bulbs run cooler than incandescents, and water may condense on the exterior of the bulb, presenting a significant shock hazard in an ungrounded fixture.
Corrosion
The prongs on a traditional fluorescent tube are made of metal and are relatively exposed to the surrounding air even when installed in a fixture. Exposing the bulb to moist air will cause these prongs to corrode, reducing the performance and life of the bulb. It is advisable to avoid using fluorescent bulbs in wet or humid areas, opting instead for a sealed incandescent, mercury vapor or LED light source.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
最も参考になった回答
The old style magnetic ballasts can lose voltage in humid environments which can prevent the necessary arc between the ends of the bulb. Either replace with a fixture with an electronic ballast, or alternatively, cut a narrow (1/4”-1/2”) strip of foil and attach it to the back of the bulb from end to end but stopping just short of the metal on each end. This helps a low voltage ballast make the initial arc required to light the bulb.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Thanks for the detailed post. I am renting an apt with fluorescent fixtures throughout. And the landlord won't be changing them out any time soon. The lighting in the kitchen and bathroom quit working as soon as the humidity levels go up. It is frustrating to say the least. I had read about the foil fix before but it wasn't really clear to me why or how to do it. Your post perfectly explains everything I need to try this trick. Thanks for your help:) I'm going to try it out this weekend.
さんによる
I am having the same issue with the lights not turning on in high humidity. I'd like to try the aluminum foil technique but was wondering what is the best way to attach it? What material do use to affix it?
さんによる
I'm not quite understanding the foil- where it goes and where it doesn't ? And could this spark a fire?
さんによる
コメントを追加
Good answers; in wet or humid areas many times florescent fixtures are enclosed. Also, your bulbs may be dirty - when moistened by humidity it can form a short circuit around the bulb and keep it from striking (starting).
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
A co-worker told me of this and I'm going to try on some that have this hard start when humid problem. I'm especially hopeful this will work because the bulbs are in a shop where a lot of mower blade sharpening is done so they are probably covered in metal dust!
さんによる
コメントを追加
Hello Lee,
It's possible that the humidity and moisture are affecting the electrical components of your light fixtures, causing them to malfunction. When the moisture content in the air is high, it can affect the electrical contacts, ballasts, and bulbs of the light fixtures, making it harder to turn them on.
One solution is to try using a dehumidifier in your kitchen to reduce the humidity levels, which may help alleviate the problem. Additionally, you may want to check the wiring and connections of the light fixtures to ensure they are secure and properly insulated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lee さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 38
過去 30 日: 122
今までの合計 39,651
