How can I get my mattress repaired?
Can anyone fix a ripped mattress I want it done professionally? I can not seem to find anyone at this time
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's a video on how to do it: https://www.hunker.com/13403914/mattress...
If you don't want to do it yourself, call fabric store and ask if they have a contact.
このアンサーは役に立ちましたか?
A mattress is simply covered in a lot of fabric with a lot of sewing.
Consider researching mobile seamstresses or tailors to see if they are willing to repair the mattress.
Google and Yelp! are your best resources for this.
このアンサーは役に立ちましたか?
Is there anyone who can clean a new mattress that has had about a cup of oil spilt on one corner of a new king size mattress?
Just use a standard carpet cleaner. Mattresses are large enough that you can run a carpet cleaner over a mattress like you use it on the floor.
Yes, you can fix the ripped mattress. Spray inside the tear with adhesive, covering both sides of the tear within the foam; be sure some of the adhesive reaches near the edges to create a lasting bond. Allow adhesive to dry for 10 to 15 seconds, then press the foam sides together, closing the tear. Hold in place for 20 or 30 seconds.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 31
過去 30 日: 136
今までの合計 7,776
1件のコメント
I need someone to fix a zipper on my mattress
Raynell McDaniels さんによる
