メインコンテンツにスキップ
This second generation drone was first released on November 4, 2015. The Ehang GHOSTDRONE Aerial Plus 2.0 includes a 4k sports camera, VR goggles for first-person flying, and iOS/Android compatibility for drone operation.
2回答 すべてを表示
My ghostdrone not connecting to device
ok. thank you ifix... am having serious troble connecting my ghostdrone to my device even after connecting the g-box and the VR goggle but wont just connect to device.
I tried binding it but still no respones from the drone.
Is there a way round it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Yo lo he conseguido después de abrir el drone
y cambiar la SD de dentro por otra,,la tarjeta SD se había bloqueado ,así solucione mi problema
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Disculpa no tendras la version nueva del firmare del ghostdrone vr 2.0
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
El mil si se conecta pero no puedo lograr k pase los 3 puntos de calibracion
さんによる
コメントを追加
I have the same problem, and can’t find anything online for it!! I bought my brand new with a bad battery on offer up, and just ordered a refurbished battery on eBay! But when I try to connect the drone the first time all the colorful light when on and I connect the app and everything so it asked me to update the firmware and I did. After that the drone does not connect at all! I am able to connect to the vr but the drone does not connect. When I do the binding it says it’s successful but after 3 sec it shows disconnected! The green light on the front blink a few time and it goes off and the drone starts making a really annoying noise! I have tried pulling out the sd card removing all the files ( I saved the files on the pc just in case) and replacing it with and empty sd card but nothing and the green light doesn’t even turn. So I put the files back into the Sid card and installed it back on the drone!but I still get nothing only the green light blink and the annoying noise start again. I tried connecting to the pc using a usb cable and the user toolkit as the official EHANG website suggests but even there the drone does not connect. I don’t believe it’s a hardware problem but a firmware problem! The worse part is that EHANG from what I understand is no longer doing updates on those as they are apparently no longer on the consumer market. I should’ve done more research on it before purchasing! But all I did was watch a few YouTube reviews videos on it! I have new had or even played with a drone before so when I saw it for sale on offerup for only $60 I had to have it! At first I thought I could fix the battery cells myself they were only $35 on amazon prime and how hard could it be to solder a battery cell.( apparently you need a spot welder which I don’t have or know someone who does) and that was mistake number 2! Lost another $35. So I found a refurbished battery on ebay from a really good seller for a little over $100 and he gives you a rebate for your core! Here is the link for the battery
https://ebay.us/C0JlOL
Never send my as I open it to try do solder the cell and burned the board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ambrose Osafile さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,109
