メインコンテンツにスキップ
Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
11回答 すべてを表示
Front glass undamaged, when screen turned on I see cracks
I have just recently sat on my Acer Iconia Tab 10 A3-A40. There are no scratches on the front glass, if I run my fingers over it, I do not feel anything.
When I turn on the screen, it shows cracks over black background, touch is not working.
Can someone please help me find what parts I need to buy? I am unsure, but I believe I need to buy a LCD screen with digitizer. Or can I buy only LCD screen and re-use the digitizer?
thank you for your help guys!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
It seems that those are all the symptoms of a cracked LCD, so you would only need a LCD, and you could most likely reuse the digitizer. Hope that helps!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you Reed! I will order an LCD and try to fix it.
さんによる
@peterslo No problem! I'm glad I could be of assistance! Good luck with the repair!
さんによる
コメントを追加
回答を追加する
peter さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 6
今までの合計 188
