メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
iPhone 6s+ touch lag on battery, but not when charging after screen an
I replaced a screen and battery on a 6s+. The customer brought it back afterwards because he said it was laggy. I did a factory reset on it but that didn't work. So I tested the phone with a couple other new screens but that didn't fix it. I also tried a couple new batteries but that didn't fix it. I noticed it was fine when charging but not when unplugged. Any thoughts on what might cause this?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
As a shop owner, I'll safely assume that you can vouch for the good working condition of the replacement parts you tried. In that case, it's hard to say what could be causing the problem. Did the customer give you any background history of the device?
Considering all of the issues with the iPhone 6S, aftermarket screens and iOS 11 (you can read more on that here) as well as the throttling issues Apple has admitted to (you can read on that here), it sounds like it could be a lot of things. Make sure the phone is up to date, try some known-good parts (again) and see. If that doesn't solve it, then I suspect there may be a deeper issue, perhaps on the logic board.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Maybe try buying an iCloud locked 6S and try using some parts from that and see if that works. If not it’s probably a logicboard issue. Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nick Stone さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 3,196
