メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
締切られた回答
New screen on 3G but now Apple logo stuck + moving circle
I replaced a screen on a 3g the apple logo is stuck on with revolving circle constantly moving tried hard reboot and via computor still the same even tried replaceing everything exept the logic board still the same, does anyone think its a logic board problem Thanks Sorry did not replace the battery should i give that a try ???? please help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
was the screen working before the change? or couldn't you tell? by screen do you mean lcd or digitiser?
any drop/water damage?
さんによる
Do you get an error when restoring via itunes?
Possibly use irecovery to change the env to auto-boot true?
さんによる
Hi Everyone, Thank you very much for help but found the problem I had replaced the mid frame including the digitizer so I replaced just a Dig onto the old mid frame hey presto its working fine can only presume the mid frame had someting to do with it Happy now Many thanks
さんによる
did you try to restore via itunes.
i think is software problem.. just try first the basic troubleshooting... software first...
question.- what did you do last time before its happen?
さんによる
take a look at kevins comments about this... he has sorted the problem out. It wasn't software
さんによる
コメントを追加
6件の回答
ベストアンサー
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Great job Kevin, now all you have to do is accept your answer so we all know that your case is closed.
さんによる
What is a 'Dig' ?
さんによる
@Michel, probably abbreviation for digitizer...
さんによる
コメントを追加
最も参考になった回答
This is to help others with the problem:
Take the OEM part that you didnt replace, like the LCD and pop it onto the phone without the digitizer. One by one try parts like this. I have noticed that many aftermarket parts can cause endless boot issues. once the phone boots up, try installing the other part, and you will notice it sometimes freezes up. Quality control in China sucks, I can't tell you how many times I've had to troubleshoot like this.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Excellent point!
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What is a 'Dig' ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For me it was connector #3 that did it. disconnecting that cable lets me boot properly now.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That means your #3 ribbon is damaged and causing a short and thus the loop. Replace that ribbon and see if that helps.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,734
