メインコンテンツにスキップ
High-end multimedia laptop by Asus.
9回答 すべてを表示
I need screws for bottom cover near hinges
Got a Asus N551Jq trying desperately to find a screw that will secure bottom case to the front case hinges stay shut. (the two holes on bottom cover) requires I believe two long screws anyone know where I can purchase this? Or know screw type looking everywhere.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I already know about this but I don't know what size I need and postage is ridiculous to take a gamble.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi all,
just in case anyone needs it in the future.
Red: 2 screws (M2.5*10L) / connect bottom - hinge - topcase
Blue: 4 screws (M2*5L)
Purple: 2 screws (M2*3L)
Here you’ll need 2 longer screws (M2*16L)
These 6 screws (M2.5*4.5L) connect hinges to the bottom case
Basically, this list is applicable to both gaming (ROG G551 / GL551 / G58 series) and non-gaming (N551 series) models. Some minor differences may exist for TOUCH models.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
hey do you have something like this for the asus fx504gm model?
さんによる
コメントを追加
And a bit more detailed overview for the FX504GM:
Let me know if you need more info about some other screws for this laptop.
Cheers!
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
perfect thanks! do you also know the screws that connect the hinge to the lcd back(behind the lcd bezel)
さんによる
@Dante Xavier, yeah, you'll need 2x M2*2,5L for the top and 4x M2,5*3L for the underside of the LCD cover.
Just to add, LCD panel should be attached using 4x M2*2.5L.
Cheers!
さんによる
So in total 8 x M2,5*3L for the both hinges in the bottom left and right to be connected right? Also 2x M2*2,5L for the top of each hinge to the back lcd cover?
さんによる
@Dante Xavier, nope, just as said before 2+4 is for both hinges.
Take a look - I've added a picture of how it should look like :)
さんによる
thanks so much! also for the hinges in the second picture is that 4 on each side for a total of 8?
さんによる
1以上のコメントを表示
コメントを追加
Hi,
Don't know if this is a help to you or not.
Here is a link that shows ''all'' the parts that are available for your laptop.
Scroll down and click on the screw link to get a list of the screws and their sizes,
e.g. M2.5*10L = metric screw 2.5mm wide x 10mm long
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi,
Well there are only two long screws sizes mentioned and since they are a standard metric size suggest you try the local hardware store.
Either M2*16L or M2.5*10L
さんによる
コメントを追加
Hi @Dante Xavier
Not the same detail as above but here are all the screws sizes available for the laptop model.
Just select the "Screw (14)" checkbox.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adam UKGaming さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 2,599
