brakes locking up in booster
my brakes keep locking up in the booster i bougt new one install new brakes all four new master cycder bleed all lines it still locking up in the booster new vac on it to to release the brakes i take off the vac hose and it will roll what going on
Does it have ABS installed? If so you will need to use the correct method to bleed your brakes via your ABS.
sm_vulkus さんによる
no abs i notes that the fill tub don't have a wire hook up its has a wire hook up hanging but it don't have ABS braking
brian さんによる
