メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2620回答 すべてを表示
Thick shadowy black/green vertical line
Hi,
I've got a thick black/green line that goes top to bottom on the left side of my screen.. it's not solid, it's like a shadow. You can only see it on certain pictures, it's particularly visible on a blue sky. Or solid colour background.
Anyone know what it might be?
TV is a Samsung hu7200 65". It's about 2.5 years old..
Thanks
David
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
@huskymanwhat you have here is a broken panel. Check the crack lines etc. There is no repair for it but it will have be replaced.
The major issue will be to find a replacement. If you can find it, it will most likely cost more than a new TV. You could check places like ebay or craigslist to see if you find the same make and model TV as yours that is broken other than the display. Then harvest the display from that.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It is probably just that some of the pixels on that side of the screen are not registering some colors so you will probably have to replace the LCD.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a ibell b LED TV and their is a horizontal green line at the top of the TV please tell any solution
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@akshay123 you'll have to post a "clear" image of your complete screen.
さんによる
Ok, but the green line appear in half hour when i start the tv
さんによる
I have a ps4 when i was playing i saw a green horizontal line at the top of the tv can anyone sayis their any problem in ps4
or in the tv
さんによる
コメントを追加
回答を追加する
David Johnson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 4,643
