メインコンテンツにスキップ
Kindle 3はAmazonによって発売された第3世代のKindle製品です。Wi-Fiもしくは内部ストレージが4 GBの3Gコンフィギュレーションです。
76回答 すべてを表示
Strange issues with my Kindle 3
Hi everyone,
I will tell u the problems right now....
My kindle 3 showed the following screen "EMPTY BATTERY", so i tried to charged it for several hours and that seemed to work. Orange LED turned to Green LED and the kindle was alive. After a few pages, the screen froze on the sleep mode and the GREEN LED turned off. I tried to charge it again, and i saw the same result as before, but now, the LED is everytime green and it turn OFF after 5/7 seconds with a blanked page on the screen. Now im using m,y kindle while it is in charge, if i remove it to the charge, it will freeze and turn off again? any solutions? if the LED is Green, then the problem isn't the battery?
Thank YOU!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
It seems as though the battery is failing to hold the charge and needs to be replaced. Even rechargeable batteries have a lifespan.
Here is a link to the ifixit Kindle 3 バッテリーの交換 guide.
Battery suppliers are available online.
Just search for Kindle 3 battery to find one that suits you best.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Luca Sorace さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 9
今までの合計 414
