メインコンテンツにスキップ
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
59回答 すべてを表示
Unable to hear during outgoing calls
After the latest update to my BLU XL2 I am now unable to hear during outgoing calls as well as any sound with the speaker during the calls or with Google assistant. My speakers work fine when watching video. Everything is fine when I receive a call.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
7 件のコメント
You are correct @Grandy. It is the Google app. When I allow microphone permissions within the app the problem persists, but as soon as I disabled permission for the app. It went away. Thanks for your help!
さんによる
Gabe........How did you disable permission for the microphone? Thanks in advance. Joe
さんによる
I have this too! I can't hear a call when calling out, but when someone obviously answers, I press the record button & I can hear. Ugh. Thank you for the feedback, I took the ok Google advice as well as the carrier service. I'll see what happens!
さんによる
Thank you for this...I've had this same problem after the last update. Disabled the ok Google... problem solved.
さんによる
I hve buy vivo y 81 one month ago, but there a hearing problem, I am not able to hear incoming as well as out going calls . Tp hear calls , I have to on loud speaker. This the problem in this phone.
さんによる
2件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
I had this problem after the update also. I figured out it only happens while I have "Hey Google" activated. If I disable the "Hey Google" feature everything works fine.
Google account/settings/voice/voice match, and turn off Say "Ok Google" any time.
このアンサーは役に立ちましたか?
スコア 8
8 件のコメント:
Thanks for the feedback. I also corrected the issue by disabling microphone and phone permissions in all apps that had those specific permissions. There were only 5or 6 total. The issue has happened since but I haven't pinpointed the actual app that is causing the problem. I will update once I do. Thank you.
さんによる
Thanks Grandy, I can hear again. I contacted BLU and turning off "OK Google" is the remedy they're recommending as well, until a permanent solution can be found.
さんによる
Your welcome. Glad to be of help.
さんによる
Grandy, I thank you for getting me on track again. Your remedy is spot on.
さんによる
Thank You... I have been going crazy with this issue. I was about to toss my phone and get a new one.
さんによる
3件以上のコメントを表示
コメントを追加
Hello, Thanks for easy answer!
Google Talk it's looks like it is a "Bug" or "Intercellular" and "google app" need to remove forever and put "Google Company" to Bring to Court for this interception to all Mobile Phones?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have mi phone but I can't here in comming and out going calls
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gabe さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 24
今までの合計 26,816
