メインコンテンツにスキップ
ビデオ出力付きのPC用ディスプレイ(もしくはモニター)の修理ガイド
Dead 31MU97-B monitor, power board OK.
I switched my 31" LG 31MU97-B off at the wall power socket and when I switched it on again a few hours later it was dead. So, untouched between switching off and switching on.
Dead means absolutely dead – no power light, no sound to indicate it has switched on, no message about powering off in a few seconds to save energy, no sign of a backlight.
I have taken it to a PC repair shop and to an electronics company that deals with monitors (but more usually the industrial type) and both say no blown fuses, no bulging capacitors and that the power board is OK. The latter thinks the display panel itself is probably OK.
Since there is no power light, which is presumably low voltage, I'm thinking this must mean something is causing the power board to trip or shut down (almost instantly). Is it (almost) inevitably the mainboard or has someone any other suggestions? Would I be right to think the power board is capable of shutting down when feeding into a short or too high a load or demand from the mainboard?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
10 件のコメント
I have this same problem...unplugged to move the unit and when I plugged it back in, no go...nothing.
There is a local repair shop, but I have tools and knowledge to troubleshoot and would like to give it a once-over before taking it in on Monday. Does anyone have instructions for taking the back cover off...don't want to break any plastic!
TIA...
Tom
さんによる
A risky business that I did not attempt myself not having gained experience on cheaper equipment!
You can buy special little plastic levers – they seem to be often called spudgers – quite cheaply.
Coppell TV say they use a number of old plastic credit cards or others of the genre.
I've read of people using screwdrivers – maybe they succeeded without damaging the case, maybe they didn't!
さんによる
I want to take a moment to acknowledge CTR for providing exemplary customer service when the main board in my 31MU97-B failed recently.
Problem solved!!!
Thanks to a previous commenter, I contacted Coppell TV Repair. I had a surprisingly lengthy conversation with the owner who was extremely knowledgeable and gave me some tips on how to get the case apart so I could get the mainboard out and send in for repair. With his guidance, I was able to get the back cover off and remove the mainboard without damage to the case.
I shipped the mainboard out last Monday via Express Mail and the repaired board arrived today (Saturday) via the same method. Installed the board, tested it before putting the back cover back on, looked good, so I buttoned it back up and am now typing this note on the repaired display.
These guys are first class and know their stuff...highly recommended.
さんによる
In the UK, I took my monitor to Maggi Electronics Limited in Bolton (Greater Manchester) on 10 January 2018.
http://maggielectronics.co.uk
Their/my/our problem was getting a replacement mainboard. They contacted LG in the UK who directed them to Equinox in Tewkesbury. For whatever reason, they couldn't seem to get the board supplied by them,
In the meantime, I contacted LG USA and LG in Korea. Both directed me back to the UK.
We were about to give up when I decided to write to Equinox to try to find out what their relationship to LG was (8 March 2018). A week later I had a new mainboard supplied by them. The following Monday, 19 March 2018, Maggi fitted the board free for me.
I don't know what the problem was with Equinox, whether they were worried about their relationship/contract with LG in the UK, whether my contacting LG in the USA and Korea created any response in the UK, but the moral of the story would appear to be that in the UK the first priority is to secure a replacement board.
さんによる
I have three of these set up on my editing computer. All working great for a couple of years. A few months ago I moved them over to be switched by the UPS and the the problems started. No lights and seeming no power. The power supply was working and making it available to the main board. I tried the jump start method and had success for one monitor. One monitor the screen black became split in the middle and one monitor will not respond.
looking for 3 new boards. Previously I had a friend in the US ship me a board with a new chip from Coppell TV and Repair but the board was broken in other ways.
or if I could find a true 4K monitor for less than 2k, with a huge color gamut and stabile with adjustments I should buy three new monitors.
さんによる
5件以上のコメントを表示
コメントを追加
14件の回答
ベストアンサー
The freight cost was too high to use the Coppell service. In the UK, I bought a new mainboard from:
https://www.equinox.co.uk
and monitor is working well again. Maybe I should put the old one on eBay to see if someone wants to buy it to see if they can repair it with a new eeprom,
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sur ces moniteurs, il y a souvent des problèmes avec les alimentation (power) et il est judicieux de changer les condensateurs de filtrage, souvent des 1000 microfarads qui viennent de Chine. et ne sont pas fiables..
さんによる
On these monitors, there are often problems with the power supply and it is a good idea to change the filter capacitors, often 1000 microfarads which come from China. and are unreliable.
at the moment by Yannzic Edit
さんによる
コメントを追加
最も参考になった回答
I got my friend monitor LG 31MU97 with the same problem no power and LED light.
I just use PIN point test use service manual for LG 31MU97.
And i found what CPU stuck in boot loop with error report. So i just updated Firmware in ROM in IC205 (MX25L8006E) it have error checksum before. It is 1 Megabyte rom.
And after update everything works again.
I did it with two my friend monitors. It is common problem how i see.
このアンサーは役に立ちましたか?
スコア 8
12 件のコメント:
Where can you get the firmware?
さんによる
I got the firmware from LG monitor developers. I can provide it if you need.
You should have SPI chip programmer.
さんによる
Hello Oleg, did you reflash the firmware in circuit or did you desolder the serial flash?
And would you mind sending the firmware? How couls we get it?
thank you in advance
regards Uwe
さんによる
Oleg Gritsevc Can you provide the firmware?
Also, can you provide the information on how to program via the SPI program
さんによる
Oleg Gritzev, I’ve discovered this problem on my LG 34UM94-P and having no luck getting the firmware from LG or anywhere else. Do you happen to have access to it and could send it to me? Thanks!
さんによる
7件以上のコメントを表示
コメントを追加
I had this issue and came across this blog that helped fix it with a multimeter and an hour of my time. https://integer13.wordpress.com/2018/04/...
Hope this will help others too.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
This is called the 'jump start' method and I don't recommend to use this method. It sometimes works, but it can also destroy one of the video processors. This is explained in more detail in this video from Coppell TV Repair:
https://www.youtube.com/watch?v=o6jL2a_L...
さんによる
Here is the link with comments: https://integer13.wordpress.com/2018/04/...
さんによる
We had a power failure about a month ago. They next morning I could not turn on one of my LG 31MUY(&C-B monitors. I thought the electronics were fried. But then after looking at this page, I tried the hold the power button approach for 30 seconds, but that did nothing. Then I tried the blog approach above suggested by Andrei. Yes, it took about an hour to do, but you have no idea how happy I was when it turned on again -- without having to ship it, pay repair fees, buy a new monitor, or deal with LG's repair dept., which seems to be MIA during Corona. Thank you so much Andrei.
さんによる
Thanks for the link. Really useful in getting the cabinet apart. Playing around with the U205 chip worked, only not the way the link described. The data sheet for the MX25L8006E memory IC stated that, following a HOLD operation (which could have happened during a random shutdown, say) "To re-start communication with chip, the HOLD# must be at high and CS# must be at low." Since the HOLD# pin read high, I pulled pin#1 CS# low through a 2K resistor to pin#4 ground. (The resistor was to protect from overcurrent if pin#1 was driven by a very low impedance source.) It seems to have done the trick. (BTW, the +V shown in the pictures is +19V, while the IC is powered with only +3.3V. Fortunately, the author was only pulling the SCLK pin high through a multimeter's input impedance of 10M ohm or so, as a much lower resistance could blow out the chip.)
さんによる
I just did this 8/1/21... and having 30+ years electrionics experience was shocked and people putting meters between 19 Vdc and pins on chips. Chips signals are ground or zero for low and no higher than vcc when 1 or high... so in this case 3.3v when high.
My fix, I'm not 100% which did it.. but I think Cycling power while touching the pins is required. I first tried a 756 Ohm resister between Pins 1 & 4 ... then I tried taking Pin 6 High by touching pins 6 & 7 (shorting them... as pin 7 is already held high. and cycled power while I held the pins... the speaker beeped and the a few seconds later the screen lit up.
Not really certain which touch of the pins worked as I cycled power after teh second touch.... but for certain... I was a lot less likely to damage circutis by not touching anythign to 19Volts not matter what.
さんによる
コメントを追加
I had the same issue. 31MU97B Monitor died when the UPS was turned off while it was powered on. No lights would light up, nothing on the display. All the voltages looked good. No parts looked bad. So I bought the eeprom replacement from:
http://www.coppelltvrepair.com/p/1483/lg...
Swapped this out and I'm up and running again. Your mileage may vary.
It seems strange that a read only eeprom chip would die, so I was very skeptical to start with, but this did fix it.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
I have the same issue with my 31mu97 though I have not isolated the issue bto the eeprom. I'm debating if to send it in or not. How difficult was it to solder the new chip in place?
If the power supply is good is the eeprom the most likely culprit with this monitor?
さんによる
tysm-
Is the link above from coppelltvrepair the whole replacement board?
Mark
さんによる
Bumping this. Is the part the whole board to replace or just the chip?
さんによる
The website says: "...offers the EEPROM IC containing the firmware for LG 31MU97-B main board 62882801 / 31MU97/LM41C / EAX66105904."
So it's just the chip. Also, $10 for a full main board would be pretty crazy.
さんによる
Somehow I never saw email notifications for these comments, apologies.
I just had this same problem happen again. The "jumpstart" method wouldn't fix it again. So I ordered another eeprom chip and its working again.
The link above is just the chip... I think i ordered it from them again, but through ebay this time.
If you have a small'ish soldering iron and some tweasers, its not too hard to replace the chip. It's an 8 pin SOIC. The hardest part is getting the clamshell case apart with prying tools.
さんによる
コメントを追加
So, my LG 31MU97-B has developed this problem again. I wonder if it is possible in this old thread to establish clearly the procedure to fix the most probable cause.
So, it’s the IC205 on the mainboard – quite easily found (once you can get to the mainboard – I’ve a spare one, of course). This chip is an MX25L8006EM2I-12G.
I buy a CH341A SPI Programmer with SOP8 clip.
Can I then follow this guide?
https://www.win-raid.com/t4287f16-GUIDE-...
I plug the programmer into a USB port and correctly connect the clip (connected to the programmer) to the EEPROM IC205 and issue on my Linux computer command line:
$ sudo flashrom --programmer ch341a_spi -r backup.bin
If I get no errors, I then issue the command:
$ sudo flashrom --programmer ch341a_spi -w lg31mu97.bin
having downloaded lg31mu97.bin from the link given in the WordPress blog:
http://aleksikoski.com/temp/lg31mu97.bin
Actually, I’m not too sure you’d be too advised to do this straight out. The CH341A would supply the EEPROM chip IC205 with the required supply voltage of 3.3V. However, the CH341A appears to operate at 5V and supply programming signals at around that voltage to the chip it is programming. It may therefore damage the chip we are trying to reprogram and other devices on the mainboard. Apparently, it’s possible to make the CH341A use the 3.3V supply at which it will still run. This solution involves wire and solder.
Got mine fixed again. Pete of Pete’s Computers (Manchester, UK) reprogrammed the IC205 chip for me.
http://peterscomputers.co.uk
Comments and advice very welcome, of course.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here is all the necessary software needed to fix this. You need a CH341A programmer that just clips onto the chip.
It includes the firmware, software & drivers for CH341A programmer. Once you have it connected, you selected 25/25 SPI chip and it will automatically detect (chip name ends with 06E if i remember correctly) it if its properly connected and drivers are installed. It seems to always complain that drivers are not installed.. even if they are.
Just load the firmware and click AUTO.
  1. https://aleksikoski.com/temp/eeprom_prog...
I kinda made this as a backup for myself, as i need to do this occasionally if i lose power abruptly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the power board is OK the power ON light should appear. If you disconnect the harness from power board to mainboard, are the voltages correct? There's a polyfuse in series with the mains input, it could have gone entirely.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The monitor is currently with an electronics company – I've no practice pulling bezels apart, my multimeter hails from the late 1960's and it's decades since I wielded my soldering iron.
I imagine disconnecting the power board from the mainboard is what they did, though when I spoke to them they hadn't spotted the existence of the power light.
According to these people:
http://www.coppelltvrepair.com/p/1482/re...
a dead monitor can result from a problem with the mainboard. Certainly I'm wondering what conditions must be met for the power light to come on.
さんによる
I sent my main board to Coppell TV repair and they found the fault quickly and fixed it. I don't see anything different about the board after the repair, but it works again. I purchased the service manual and tested the 19V power supply, and the four power supplies on the main board, all were OK before I sent it to Coppell.
さんによる
コメントを追加
This problem is caused by bad software in an EEPROM chip on the mainboard (IC205) and can be repaired easily. If you flash an image of this software on this chip, your monitor will come back to life again. I did this repair for about 5 times and all attempts were successful.
If your LG 31MU97-B monitor is completely dead and you are not living in The Netherlands, please send your mainboard to me. I can fix this issue and send the mainboard back to you. If you live in The Netherlands, you can make an appointment via my website mentioned below.
Kind regards,
Erwin Aarnoudse
Monitorkapot.nl
The Netherlands
https://www.monitorkapot.nl
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
My Husband used LG software for ROM update.
Just turn monitor, use USB cable or Service RS232 cable connected to VGA.
Run update rom from LG database use monitor revision.
Power cycle. Reset settings. 10 minutes and no need send monitor to other countries.
さんによる
How do you run an update from an LG database? Can you explain this in more detail?
さんによる
Fennella,
Can you please provide more information?
I'd like to try to update the ROM prior to opening up my monitor.
After doing some searching on the internet I couldn't find an update file, can you tell us where you got this?
What computer software did you use to perform this update?
Thanks!
Danny
さんによる
I can also flash the EEPROM of the LG 31MU97Z-B mainboard. This version of the mainboard contains a Thunderbolt port. Please contact me on https://www.monitorkapot.nl if you need help with this mainboard.
さんによる
Hi everybody. I have the same problem - a dead LG 31MU97-B. Is there any way to try the eeprom update via thunderbolt or usb prior to opening up the whole thing? I just pried open a cheaper monitor and it’s a huge mess.
If I can avoid opening it or sending in the board. Any help is much appreciated!
さんによる
2件以上のコメントを表示
コメントを追加
I know this is a pretty old post,, butI want to add my $.02.
I had 2 of these LG 31MU97-B’s sitting around for months from owners who hoped I could fix these. Both users gave up quickly, not wanting to spend more money on a problematic monitor. On an off chance that most things are simple I asked LG how to reset the board. Sitting around for months didn’t do it apparently. LG got back to me instructing me to hold the power button in for 30 seconds unplugged. Naw too easy and not logical. These were both dead as dead can be with not response. Boom! both started functioning perfectly again. What?? I’m still baffled.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Hi, would you have happened to have taken a firmware dump from one of these monitors as it seems to extremely difficult to track down the firmware.. to re-flash the eeprom... I have the hardware needed just can not find the file/bin/firmware i need.
さんによる
You say "to hold the power button in for 30 seconds unplugged." Can you explain more in detail? I suppose you mean to keep the joystick at the bottom pressed for 30 sec when the monitor is not plugged in the socket? (did nothing for me so far, so I probably got it wrong).
さんによる
Yes, that is the power button. It resets the stored efi. If that didn't work there is probably a hardware issue.
さんによる
Tried this as well with an August 2016 date on the back of the monitor. No joy. Died after a 5 second power outage.
Our experience has been if the monitor loses power while it is on, there is a decent chance it will not come back on. Fix is to replace the eeprom.
さんによる
コメントを追加
I have reset mine with guide with https://integer13.wordpress.com/2018/04/...
for awhile then all went back again after power out in my home area. :(
now trick with Amp meter does not work :(.
I have purchased replacement IC205 ROM from ebay but I do not have tools to do the board repair :(
My question is What do I need to do the replacement IC succesfully? what tools do I need?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So what is your question?
さんによる
Use the eeprom programmer discussed in that wordpress.com posting. It costs $10 from Amazon. Much easier than resoldering. You could even pull the current firmware from the eeprom that you bought on ebay.
さんによる
コメントを追加
My 34UC87C led me here.
though it’s a different monitor the jumping worked here’s what I did.
I jumped pins 8 and 6 without luck. Then I wondered how the fix works.
If the rom is on a loop maybe screwing with the clock causes an error or jump elsewhere.
So I rapidly shorted 8 and 6 a bunch of times. It eventually worked.
pin 8 is vcc so safer than that post about an ammeter.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How were you able to open the back of your 34UC87C? All of the tutorials I have found online seem to be for different models with more of a clamshell design, whereas the 34UC87C has more overlap between the front and back panels. When I've tried to use a flathead screwdriver to pry what I assume are clips, I've seen no movement at all and have actually cracked the front cover mildly.
さんによる
コメントを追加
Shorting 19vDC to a small EEPROM seems like a bad idea to me, so I found these instructions instead.
This comment was pulled from https://integer13.wordpress.com/2018/04/...
Posted by the user: ds11111 at 2020/01/27 AT 12:35 AM
– Ordered the CH341A programmer with a clip ($10): https://www.amazon.com/gp/product/B07R8S...
– There is a good video on how to use the CH341A programmer for those that are not familiar with the process: https://www.youtube.com/watch?v=2Y06x1f2...
The video explains in detail how to do the programming in a Linux or Windows operating system. This is the software you will need to download and install in your notebook to use the CH341A programmer: https://www.sendspace.com/file/gtcmvd
(The CH341A software is available in many sites btw, v1.3 or above should work fine)
– Open the monitor removing the back (good instructions here: https://www.youtube.com/watch?v=lpWgPESO... )
[EDIT]⏎
A small note here:⏎
1. My AV software called this potentially unwanted software and grabbed it. I used this software with my AV software running (after whitelisting it and nothing malicious occurred). ⏎
2. Use the chip detect to try and sniff out what chip you have, this is the best approach so you don't have to try and guess at the settings.⏎
3. Install the drivers first, before plugging anything in.⏎
4. The chip in both of my monitors is a MX25L8006E, your mileage may vary here. I used the 25 SPI BIOS section of the programmer with its default settings.⏎
[/EDIT]
– Using the CH341A programming software and instructions in the video above, first erase the software (don’t forget to erase first or you will get an error message) and then write using the monitor software for the EEPROM chip: http://aleksikoski.com/temp/lg31mu97.bin
– Unplug everything and check if you can turn on the monitor.
– If you can turn on the monitor, reassembly it carefully
Some thoughts:
– The lg31mu97.bin downloaded from the link above seemed to have a problem with the EDID and my computer would just recognize it as a ‘Generic PnP Monitor’. So, since now the monitor would turn on I had to go to the ‘service menu’ and perform 2 steps: WRITE EDID (change it to Yes) and NVRAM INT (change it to yes). This will ‘rewrite’ the EEPROM from an internal copy. Turn the monitor off and on, reboot your computer and it should now show LG 31MU97 in the “Windows Device Manager Monitors” list and work properly with your graphics card. (Note: you can find instructions on how to access the service menu here: https://forums.blurbusters.com/viewtopic... . Important: disconnect the DP cable or any graphics cable to access the service menu, I had to try several times to be able to access the service menu)
– When performing the steps above, I realized, that maybe I should have just plugged the programmer and try to turn on the monitor without erasing or writing anything. I wonder if the small voltage applied by the CH341A programmer would resuscitate the EEPROM and then I could use the monitor own ‘service menu’ to rewrite the EEPROM. Someone posting in this thread in the future can confirm if this works: just plugging the programmer to ‘wake’ the EEPROM (most likely not, but I will try that next time if the problem reoccurs).
Cost of repair: $10
I'm adding the following because they are EXTREMELY handy.
Service Manual is here:
https://drive.google.com/file/d/1YBZRK6u...
Here's how you get into the service menu:
1. Power off, disconnect everything but the power cord, then turn the power switch on, DO NOT press the power button on the middle of the joystick yet
2. Push left 3 times, then right 1 time, and then press the joystick button (This turns on the monitor)
3. Then press left or right and you should get in service menu.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
here's another resource for the firmware image incase the original goes dark.
https://github.com/switchb0x/LG31mu97-Fi...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Gents,
first of all a huge THANK YOU! to all contributors. I successfully desoldered the EEprom, programmed it and soldered it back into its place. Bingo, works like a new one! So I thought I'd tackle my other LG31MU97 that was sitting in the corner for quite a while, too. I'm not 100% sure what happened to it. I'm sure though it's not the usual power cut. I tried the same procedure but without success. I THINK what I MIGHT have accidentally done is hit "NVRAM INIT" in the service menu. If this was the case, what would it do and how can I fix it?
Thanks an awful lot again!
このアンサーは役に立ちましたか?
スコア 0
12 件のコメント:
Did you check your power supply? These modules can become faulty too.
さんによる
I didn't because the screen went black when I was browsing through the service menu and I felt like this was the root cause of the problem. It sounds like a good idea to check voltages though. Thanks for the suggestion, will do this later today and report back.
さんによる
@monitorkapot
I get 19.17V from the power board.
さんによる
@alfred3778 Ok, then the issue is on the mainboard. You could try to reflash the EEPROM once again. Maybe something went wrong in your last attempt.
さんによる
@monitorkapot Thanks a lot for your time dealing with my LG's issue! I would have to desolder and resolder again since the clamp doesn't get good contact when the chip is soldered to the board. I had flashed the EEprom (using flashrom and the binary file available at github) which went well. It also ran a verify which stated the binary read from the chip was the same as the source file.
Do you know what selecting "NVRAM INIT" in the service menu would do? If there is no other way I certainly would be willing to try again with the EEprom. Thanks again!
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
Robert Tucker さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 127
今までの合計 24,268
