Want to keep old screen with broken home button flex
Basically, I broke the home button flex on my OEM iPhone 7 screen (the part that goes from the screen to the logic board). I had an iPhone 7 screen lying around, but it's not OEM, and I want to transfer the non-broken home button flex cable from the non-OEM screen to my old broken OEM screen.
How should I go about doing this?
4 件のコメント
I tore the HB ribbon cable connecting the screen and the logic board. The thing is, I have a perfectly fine working OEM LCD, the only problem being that torn part. Is there any way I can KEEP the OLD LCD touch screen and only replace that singular cable?
Jonathan Lalande さんによる
Not easily, no. That cable is integrated into the backlight and force touch panel. I imagine it’s doable it has patience, Heat, and soft tools. You could swap that backplate out completely.
Joshua Dworning さんによる
Is there a tutorial for that process?
Not really as far as I know, no. I just experimented on old broken display assemblies. It works a great trick if the backlight burns out and you need to recover data. I would recommend just being very careful and going slowly. Don't get your tool under the plastic as much as you can, and there's probably a ton of adhesive along the top as that's where the backlight LED strip is. That requires just being careful. Depends on how much you really need it vs buying a new screen to try again.
