メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
Can I change internal components with another size samsung tv?
Hi,
I have a samsung tv ( UE50J5500AK) the tv made a pop one day and hasnt been getting power or turning on since. Im certain its the power unit in the back. I have recently been trying to find another faulty screened tv but working . The same model number and size to move and replace all the internal circuit boards into the tv i already have. I came across a Samsung tv exactly like mine but a 48” version. Model number ( UE48J5500AK). So this tv is essentially the same country. The same year. The same model number but 2” different size screen. Isit possible to use these parts to replace with the ones in the tv i have? I read a forum of someone doing it with different size screens in older tvs which worked. If not, what about using a tv with the same screen size but slight different model specifications like UE50J6000AK.
Any help appreciated, thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi, I am trying to do the same thing. My TV model is UN60KU6300FXZA. Would you be able to tell me the models which are interchangeable with mine?
さんによる
コメントを追加
1 件の回答
ベストアンサー
@mista_julius some of those boards interchange while others do not. This will depend on which board you specifically need.
For example the power board for your set (should be a BN44-0070E)is interchangeable with the following :
UN50J6300AFXZA DH01
UN50J6300AFXZA DH02
UN55J6300AFXZA TH01
UN55J6300AFXZA UH02
UN55J6300AFXZA VH03
UN50J5500AFXZA II03
UN50J5500AFXZA DI02
UN50J5500AFXZA II01
UN55J5300AFXZP DH01
UN55J5300AFXZP DH02
UN55J5300AFXZP AA03
Not saying that the set UE50J6000AK does not work but there is not a whole lot of service information out for it. Doing a search by the individual board numbers usually gets better results.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks I appreciate the reply. I just viewed up on the PSU board on ebay u suggested. It is exactly the same as the one in the tv. Thinking to buy and try one of the boards on there. Seems much easier and cheaper thanks alot.
さんによる
Anyone can suggest Interchangeable power boards with BN44-00667A? Thank you.
さんによる
@rednci it's the same power board for these models
HG46NA570LBXZA
HG46NA578LBXZA
HG46NA590LBXZA
LH46HDBPLGA/ZA
UN46EH5000FXZA
UN46EH5300FXZA
UN46EH5050FXZA
as well as a few others. No interchangeable board listed, which does not mean you could not find one, but you will really have to dig for it. Also, the power board is still widely available so there should be no immediate reason to find an interchangeable board.
さんによる
コメントを追加
回答を追加する
J J さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 33
過去 30 日: 115
今までの合計 11,542
