メインコンテンツにスキップ
グーグル5番目のネクサスフォン。2013年10月31日に正式発表され、4.95インチ1080pディスプレイ、2.26GHz Snapdragonプロセッサ、LTEをサポート。Android 4.4.2、KITKATを搭載。製造はLG。
222回答 すべてを表示
[Solved] Nexus 5 Screen is not working properly!
Hi,
I am not able to understand why my Nexus 5 screen doesn't work properly. It seems that the phone is working as I could hear some notifications. What could be a fix for this problem?
Update (01/20/2018)
Changing the flex cable solved this problem!
Thanks guys for your comments.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @mgupta70 ,
Has the phone been dropped or gotten wet at all?
さんによる
Hi,
The phone hasn't been under any water or physical shock/damage.
Still I am facing this problem. And it is not a software problem, I believe. I tried all sorts of resetting techniques.
I am not sure what to repair, the flex cable or replace the LCD/touch assembly entirely. Any help in this matter is appreciated!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Mohit @mgupta70 a screen just going bad doesnt happen very often without a catalysis . SO lets assume the worst and start to tear it down as if we are going to replace the LCD They can be purchased onebayfor as cheap as 30 dollars This guide can help with the teardown
Nexus 5 LCD Screen & Digitizer Assembly Replacement
But as were not sure this is the whole problem examine the logic board closely as you tear it down . Look for corrosion or discoloration .Next make sure all cables are connected securely and correctly as you disconnect them. Look for rips or tears in ribbon cables check for cracks in any folded ribbon cables. Check for any changes in color and or burn marks . If all seems fine then proceed with the screen replacement . Hope this helps
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for your comment!
I have ordered a flex cable first to try and fix this issue. I will do a complete teardown as you suggested and look for faults in case I am not able to solve this problem by just replacing the flex cable.
Thanks a ton!
さんによる
Hi @mgupta70 ,
This link may also be of interest to you. Read the last post at the bottom of the page.
さんによる
コメントを追加
回答を追加する
Mohit Gupta さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 11
今までの合計 2,916
